Discussion topic: No hayu
This message was authored by: Dal33
No hayu
Can someone clarify what sky package you need to get hayu on demand.
I have sky signature which I thought included it, but nothing works, just a message saying 'you cannot download this programme as you don't have the correct subscription'
Re: No hayu
@Dal33 signature is adequate however if you aren't paying sky for the entertainment hd add on make sure you are downloading the sd version
Avatar for Dal33
Thanks, that worked, can watch in SD. (Wish this was mentioned in all the sky help pages I've gone through).
thanks Steve.
