Discussion topic: No channels
Message posted on 05 Feb 2025 08:49 PM
No channels
All channels were working perfectly on the tv attached to the minibox. Then no channels and a message on the screen: "Please scan channels. No channels have been installed. Please scan channels via the TV menu."
All channels working perfectly on the TV attached to the main Sky Box.
Message posted on 05 Feb 2025 09:01 PM
Re: No channels
That message is coming from your TV, not the mini.
Ensure the TV input is set to the correct HDMI source. Hitting the Sky(or home) button on the remote may send a CEC signal to select it automatically.
Re: No channels
That's a message from your TV, not from your Mini box. In the first instance, check that your TV is switched to the HDMI input that your Mini box is connected to. If that's ok, try restarting your Mini by switching off at the plug for a minute or so.
Message posted on 05 Feb 2025 09:02 PM
Re: No channels
@Derek1983 That's a TV message anbd nithing to do with Sky Q or the minis, you'll need tio use the TV remote to select the correct HDMI input for the mini
Message posted on 05 Feb 2025 09:03 PM
Re: No channels
Hi @Derek1983
Looks like you have switched your television set to the TV Tuner instead of the HDMI input connected to your Q box.
Yse your television set remote (or the Q remote) to cycle through the television setninputs
