Discussion topic: No apps on sky Q
This message was authored by: gna5
No apps on sky Q
On my sky Q box I only have the peacock app. Software is uptodate, i've restarted the box, done app refresh and still no apps. Any advice beyond the usual?
Re: No apps on sky Q
Hi @gna5
The App refresh can take up to 24 hrs.
If there is still nothing try refreshing the Apps again
Avatar for gna5
Thanks for the reply - I have done app refresh multiple times over the last couple of weeks but nothing happens.
Have you carried out the Reset Settings before trying the App refresh again @gna5 ?
This message was authored by: steve30x
I had the same problem last week when I had SKY Q installed. I had no apps for three days. I had my box connected directly to my router via CAT 6 ethernet cable. I was on the phone with a SKY Rep and she suggested I disconnect the ethernet cable nd connect the box via WIFI. Immediately after connecting the SKY Q box via WIFI the apps appeared.
Just like you I tried everything. All three known methods but none of them worked. It would have been pointless doing a settings reset because it was a brand new box manufacturered last month that was newly installed. Theres no logical reason why the apps would show via wifi and not through Ethernet.
SKY Q 2TB 32B064
LG 50UQ7006
DENON X2800H 5.1.2 ATMOS
Avatar for gna5
Tried refresh apps after doing a rest and no luck
Avatar for gna5
@steve30x - the box is connected via WIFI and not by ethernet
