6
This discussion topic has been answered Discussion topic: I pressed yes instead of no when asked if it was the first time ive set up the mini sky q box.
This message was authored by: Mothernature
I have recently changed my router and thought I'd have to change the password for the WiFi on my mini sky q box. After pressing yes instead of no when asked if it's the first time I've set up the box, it now doesn't work at all.
This message was authored by: Tom-W19 Answer
Re: I pressed yes instead of no when asked if it was the first time ive set up the mini sky q box.
Hi @Mothernature
Can you try re-pairing your remote when you get to the "Step 1 of 4" screen by pointing the remote at the box and press/hold the numbers 1 and 3 for three seconds.
Try pressing Select afterwards and it should take you to "Step 2".
If the issue persists please post on this thread again and one of our Orcales/SuperUsers can get it escalated through to us so we can help you further.
Tom
Hi @Mothernature
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for Mothernature
Thank you for your reply. I have tried the above but I can't get onto the mini to the set up menu.  I am now stuck on the step 1 of 4 where I have to press 'enter' on the remote to connect via WiFi. It doesn't respond.
Remote may not be paired with the mini. Hold down 7&9.
Hi @Mothernature
Tom
Oops. 1&3 is it? I knew I should have looked it up before hitting submit!
Hi Tom, thank you very much for your advice.  I paired my remote and was then able to access settings where I entered the new router details.  There was alot of going backwards and forwards between the main sky box and the mini with a reboot in-between before I could access step 2 of 4 which allowed me to correct my mistake of pressing the wrong button! Thanks again.
