3
This discussion topic has been answered Discussion topic: No UHD on mini box
This message was authored by: mwbruce
No UHD on mini box
There should be a downscale to HD on the mini box to save all the hassle of having to record 2 programs just so that I can watch UHD on the main box and HD on the mini box.  Surely Sky can get a workaround to this.  Anyone else have a workaround ?  Just recorded some F1 UHD and can't watch while I recuperate from an operation in my bed.
Re: No UHD on mini box
@mwbruce
There isn't a workaround. UHD coverage/ recording is not available on mini boxes nor is that likely to change in the future.
@mwbruce
Sorry @mwbruce  the only workaround is, as you have suggested, record both UHD & HD, if you want to be able to watch in UHD on the main box or mini box to catch up.
@mwbruce
Taking UHD down to HD, particularly in anything like real time, without introducing unwanted image artifacts is a non-trivial computing task and way beyond the silicon found in Q (or any other 'set-top box') : even a reasonably powerful PC would have a significant render duration for that job.
Answered - Go to Answer
