Discussion topic: No TV
This message was authored by: Doug9
No TV
The sky q box is not coming up on my TV I'm just getting nothing
Re: No TV
@Doug9 are you getting any messages at all
if its your main box you could try pressing the following sequence of buttons on your remote the home button then 1080 then the home button again
I'm assuming you have tried
A checking the TV is on the correct HDMI out put
B you have tried rebooting your Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: No TV
Hi @Doug9
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
