Discussion topic: Box not working
This message was authored by Mark1241 This message was authored by: Mark1241
Box not working
Sky box has frozen. Blue circle in middle spinning and red light stuck on. Cannot turn box on
Re: Box not working
Hi @Mark1241
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
