Discussion topic: No Sky Q
Message posted on 10 Sep 2023 04:15 PM
No Sky Q
Hi Sky, We have no Sky this the message on the screen: ' Weak or No Signal'
Check the aerial cable connection and check saved channels.
Message posted on 10 Sep 2023 04:21 PM - last edited: 10 Sep 2023 04:21 PM
Re: No Sky Q
@RalphJones2052 wrote:Hi Sky, We have no Sky this the message on the screen: ' Weak or No Signal'
Nope, you're talking to other customers and not Sky.
That message sounds it's your TV (Clue as Sky boxes do not have aerial connections) and not Sky box. Change the AV input on your TV... (Try hitting the Sky button or use your TV remote to change it)
