Discussion topic: No Sky Q connection
This message was authored by: Tina662
No Sky Q connection
My two televisions are saying not connected to sky Q box, I have tried resetting and all the lights on the boxes are green but still will not work, my main tv comes up with a message for a moment saying place sky card chip facing up but I haven't touched that, but then the main tv where the main box is works but the other 2 tv don't just saying not connected
Re: No Sky Q connection
Hi @Tina662
Reboot the mini as above.  Start with the mini nearest to the main Q box.
As you are on Sky Broadband if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.  Follow the same procedure for other mini.
