Discussion topic: No Sky Q Planner for the past four days
This message was authored by: HH62
We have had no Sky Q Planner for the past four days on any of the three sky Q boxes. Any ideas?
KDH
Re: No Sky Q Planner for the past four days
@HH62
Try a reboot of your broadband, then reboot the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
