Discussion topic: No Sky Q Internet Connection
This message was authored by: Sally91
I've spent 2 hours following guides to get my sky Q box to work. There is no network connection. I have done the following: 1. gone to settings and clicked on network connection (which has a cross). I then go to set up, held the WPS button on router. StilL doesn't work. 2. I've reset the router, the hub, the SkyQ box.... nothing. 3. I can't find a phone number to call anyone! 4. I'm a Sky VIP member for 3 years and feeling very frustrated. Any support welcome. Thank you.
Re: No Sky Q Internet Connection
@Sally91 who is your broadband provider is it Sky or a third party ?
Hi @Sally91
Try the following procedure again.
