Discussion topic: No Signal
This message was authored by: Liam32
No Signal
There is no signal to our sky Q box from our TV
I have reset everything
But still no issue
Re: No Signal
@Liam32
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
This message was authored by: Seo-OR
Re: No Signal
I am also getting this issue tonight.
Was working fine last night.
All connections fine
