Discussion topic: No. Sig
This message was authored by: SHANTI+LAL+CHAWLA
No. Sig
No satellite signal
Avatar for SHANTI+LAL+CHAWLA
Re: No. Sig
I have tried all the ways but not successful, I need an engineer visit
Re: No. Sig
@SHANTI+LAL+CHAWLA
No signal and no satellite signal are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
