4
This discussion topic has been answered Discussion topic: No Satellite Signal on all channels accept BBC, ITV, 4 & 5
This message was authored by: darling412001
As title says my SkyQ box will only receive BBC, ITV, Channel 4 and Channel 5. All others are displaying 'No Satellite Signal' message. I am on a communal system using SCR. Any ideas if it's my box or in the communal system?
Sky Stream
Sony A95K
Sony HT-A9
Hyperoptic FTTP 1.0Gbps
Re: No Satellite Signal on all channels accept BBC, ITV, 4 & 5
@darling412001
A no satellite signal message is a dish alignment issue.
This message was authored by: Scampifries81
Yeah I am having problems too. Also communal. Signal in and out picture pixelating. Not good sort it out sky pay enough as it is!!!!
@darling412001 @Scampifries81
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish). As you are connected to a communal dish you need to liaise directly with your building management company / landlord who will have their approved engineers to contact.
It’s worth noting that:
Avatar for darling412001
Level 4 icon
Seems I was incorrect and there are other channels that I can still receive as well as BBC etc. Can I diagnose if the fault is in my box and Sky would need to send an engineer, or the fault is in the dish/communal distribution system in which case I need my building management company to get someone out?
Sky Stream
Sony A95K
Sony HT-A9
@darling412001
