4
This discussion topic has been answered Discussion topic: No ITVX on new Sky q mini box
This message was authored by: PandaOwl
Have new Sky q and Sky mini box today. Main Sky q box has ITVX app. Sky q mini doesn't. I've upgraded the software version on the mini. Turned tv off for a while still no ITVX?
Re: No ITVX on new Sky q mini box
Reboot the mini as above.
hi @PandaOwl
May I suggest you. also, try a refresh of your apps which is in an 'Engineer's' menu
To access it:
Main - Menu - Scroll down to Settings  & do not press Select/enter button at this stage -
Then press 0, 0, 1 followed by the enter/select button -
Scroll down to the Apps & Select Refresh
Note the refresh may take while before it happens
Avatar for PandaOwl
It's now appeared after a few hours!
Yeah it seems to download them in the background. Wouldn't surprise me if you had other apps missing that you just weren't looking for.
