Discussion topic: No ITVX on new Sky q mini box
‎04 Oct 2024 09:46 PM
Have new Sky q and Sky mini box today. Main Sky q box has ITVX app. Sky q mini doesn't. I've upgraded the software version on the mini. Turned tv off for a while still no ITVX?
‎04 Oct 2024 09:51 PM
Reboot the mini as above.
