Discussion topic: No Hardisk
This message was authored by: Marlene3
No Hardisk
After last nights outage we still cannot get our recordings. Message on screen
No hard disk
been waiting on phone for ever this afternoon but nobody answering
Re: No Hardisk
Last night's outage has meant the lines are much busier than normal.
You'll have to persevere as you'll need a box swap.
Remember to remove your viewing card...
Re: No Hardisk
No hard disk
@Marlene3 If you have not yet contacted Sky it may be that your hard drive has failed follow the link below which should lead you to ordwring a replacement box
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/an-on-screen-message-sky-q/articles/sky-q...
This message was authored by: Marlene4
Re: No Hardisk
I persevered and a very nice guy tried to
Sort it out but we still had the message no hard disk.  So we have a engineer coming Tuesday to try and save the recorded stuff and change the box,  just changing the box we would def lose it all.
I guess a lot of people in the same position.
Re: No Hardisk
@Marlene4 if the box needs changing afraid all recordings will be lost an engineer can't save recordings(there is no way to do this) then replace the box
The only way would be if the engineer got you current box working again which i doubt with a no hard drive error
