13
This discussion topic has been answered Discussion topic: No HDR
This message was authored by: Statman1971
No HDR
While watching football and F1 on UHD channels noticed they were not showing with HDR. No changes to my settings and have had no problems previously. No HDR options showing on any content. Also no HDR showing in Netflix app where it usually appears. I have reset my box but it hasn't fixed the issue.
This message was authored by: BenJoBanjo Answer
Re: No HDR
@Statman1971 wrote:
 Nothing is showing as having HDR. Also accessing Netflix via the app on the box doesn't have HDR - only via the app on my TV.
Check the HDMI connection - you may need to re-engage the handshake. Turn the power off at the wall on your TV and Q box for a few minutes then power them back on. The Q box needs to detect that your TV is capable of HLG HDR in order for it to show HDR of any kind so make sure the TV is powered on before the Q box, then let it complete the HDMI handshake.
If this doesn't sort it and you're sure that HDR is enabled on the HDMI input on your TV, then try a new HDMI cable. Get a cheap certified HDMI 2.1 cable on Amazon for less than a tenner.
Re: No HDR
Is the display settings set to 10bit?
Avatar for Statman1971
Re: No HDR
Yes it is. Normally has HDR but stopped this weekend. No changes to settings.
Re: No HDR
hi @Statman1971
Please may I just double check that you did check the setting on your box - we have known them drop back to 1080 for the odd reason
Re: No HDR
Hi @Statman1971   You say no change to settings, 2060p 10 bit, but have you checked? Remember it is the TV that switches to HLG HDR, all the Sky Q box does is output the stream.
Re: No HDR
I have checked.
Re: No HDR
Hi @Statman1971   Just for completeness, what is your box hardware version 32xxxx?
Re: No HDR
Software version is 32B106.
This message was authored by: Richardr1
Re: No HDR
Have you tried:
  1. switching the Sky box to 1080 seeing that works, and then back to 2160 with 10bit, just to make sure that doesn't nudge it into working; and
  2. the usual switch it off at the mains and then back on again [or settings 001 and reset settings] - making sure that 2160 is selected again.
Re: No HDR
Done both. Hasn't resolved the issue.
Re: No HDR
Hi @Statman1971
As far as I am aware the F1 UHD recordings I made last weekend were not HDR.
Also there are no Sky Sports that I can see showing currently on my Q box that show HDR.  Just UHD.
Looks like this may be an issue at Sky's end.
If you have Sky Cinema can you still see the UHD/HDR content there.
Re: No HDR
Re: No HDR
Re: No HDR
That's done the trick! Thanks for your help.
