Discussion topic: No BBC1 or ItV
Message posted on 23 Dec 2024 11:19 PM
No BBC1 or ItV
Had no problem before , but tonight I cannot get BBC 1 or ITV through my sky Q box , all other channels are fine ,
it says this channel is currently affected by a problem with your satellite??
surely if this was the case I would be unable to get any channels
Message posted on 24 Dec 2024 03:33 AM
Re: No BBC1 or ItV
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so check the troubleshooting in this link
No, it won't necessarily affect all channels. A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Message posted on 24 Dec 2024 07:48 AM
Re: No BBC1 or ItV
@Sheils2024 wrote:it says this channel is currently affected by a problem with your satellite [dish]??
No, they're spread across different frequencies so can be affected independently.
