Discussion topic: New sky q bix
Message posted on 29 Jul 2024 08:52 PM
New sky q bix
Can someone please advise what i need to give to DPD driver if i order a new replacement sky q box
the box, remote
any ideas which leads etc please
Message posted on 29 Jul 2024 08:55 PM - last edited: 29 Jul 2024 08:56 PM
Re: New sky q bix
the box, remote
Hi @Kevcfc
Don’t forget to keep your viewing card from the failed box.
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 29 Jul 2024 08:56 PM
Re: New sky q bix
Hi @Kevcfc To play safe, everything, people have been caught out just swapping the box and find it is a different power supply. Keep your viewing card!
