Discussion topic: My Q box has frozen on reboot saying it will be ready in a few minutes tried rebooting 3 times but e
Message posted on 29 Jul 2024 09:01 PM
Tried rebooting 3 times but each time gets stuck at the same message it will be ready in a few minutes
Message posted on 29 Jul 2024 09:08 PM
Re: My Q box has frozen on reboot saying it will be ready in a few minutes tried rebooting 3 times b
Hi @Jac58
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 29 Jul 2024 09:36 PM
Unfortunately tried all suggested but it still restarts back up in the you will be ready in a few minutes page and not going anywhere thank you for your help
Message posted on 29 Jul 2024 09:45 PM
