Discussion topic: New sky Q remote won’t connect
This message was authored by: Hannah192
Help please, I have received the new sky Q box and remote, the remote states it will not connect to my tv (same tv the old sky Q remote was connected to)
Re: New sky Q remote won’t connect
@Hannah192 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Hannah192
Thank you, I have tried this but when I search for my tv to set it up it states my tv is not found
@Hannah192 what make of TV do you have ?
This message was authored by: Sprice1878
Re: sky Q remote won’t connect
Sky remote won't connect saying unsuccessful
