Discussion topic: My new multi box as arrived but the signal is very hit andmiss.
Message posted on 16 Oct 2023 03:36 PM
My new multi box as arrived, put it together. But the signal is very hit and moss.
Message posted on 16 Oct 2023 03:47 PM
Re: My new multi box as arrived but the signal is very hit andmiss.
Hi @Marilyn3
Reboot the mini as above.
