Discussion topic: New remote
This message was authored by: Veronique93
New remote
Hi I need to order a new Sky Q remote
Re: New remote
Re: New remote
Hi @Veronique93
Assume you have tried completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
