This discussion topic has been answered Discussion topic: New keypad for remote
Message posted on 16 Mar 2026 03:41 PM
I need a new key pad for my remote control,is this possible?
Message posted on 16 Mar 2026 03:48 PM
A new remote would be required, not just the keypad.
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket. If you do that as well as the above you’ll have a spare.
In the meantime if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Message posted on 16 Mar 2026 03:45 PM
Re: New keypad for remote
@Opie4 wrote:I need a new key pad for my remote control,is this possible?
You can only have the whole remote replaced - it's not possible to just get the keypad replaced.
Fill in the form here:
Message posted on
12 May 2026
03:39 PM
- last edited:
13 May 2026
09:33 AM
by
Nimbob
I need a new Remote. I painstakingy found somewhere on Sky and they said they would send me a new one within three to five working days. Some time later I received a Text from Sky saying "Unfortunately we have not been able to process your request. If you still require a replacement please call [Removed]". I rang this number got some sort of virtual assistant who could not help and got referred back to the Sky site.
Can anyone help.
Moderator notes: Removed phone number
Message posted on 13 May 2026 09:38 AM
@Jules946 wrote:Can anyone help.
use the virtual remote from within the Sky Go app or purchase one from Argos/Amazon etc.
