7
This discussion topic has been answered Discussion topic: New free sky hub
This message was authored by: Kenzy
New free sky hub
So Ive ordered a new hub from sky because the one I have will be obselete from Dec25.  A free offer from sky. BUT I also saw my skyq box hub will not recive internet after Dec 25 but no options to update.  My skyq hub runs on wifi currently but if i run it directly off the incoming phone/internet line will it no longer work and so will i only be able to use wifi.
Re: New free sky hub
@Kenzy
It's the Q Hub (internet router) which is not going to get updates past the end of year, although it will still function to provide internet access.  Sky needs to replace them and all previous models because they don't meet new requirements for devices connected to the telephone network.
A Sky Q television box is not affected by this, and there's been no announcement of any change in their status.
@Kenzy
Avatar for Kenzy
Level 2 icon
Once I selected to replace my sky hub, I was taken to a page where it said:
  • Sky Hub: It has stopped receiving service and security updates.
Then under that was an image of my sky q box and it said:
  • Sky Q Hub: It will stop receiving service and security updates on 31 December 2025.
I assume one is my router the other my TV skyq box.
Hi @Kenzy   A Sky Q box is not a Hub.
@Kenzy wrote:
  • I assume one is my router the other my TV skyq box.
You have a Sky Q hub for the internet, you also have a Sky Q box for the TV, the two are different. It is the Sky Q hub that needs to be replaced if you have it.
@Kenzy without seeing the pictures its hard to say but I think the Sky hub is the old up right router which is not receiving any further updates the Sky Q hub is also a Sky router that looks similar to a Sky Q box and this router will stop receiving update in December 2025 you will likely receive the Sky broadband hub/router as a replacement which was introduced in 2019
Avatar for Kenzy
Level 2 icon
Great community. Thanks all.
The Sky Hub and Sky Q Hub both need replacing as they aren't compliant with new security regulations.  The Sky Broadband Hub (and the white Max Hub, not pictured) will become the only supported models.
