Discussion topic: New SkyQ box but no red light
This message was authored by: SPhelps1952
Just received a replacement SkyQ Box. All working ok except there is no red light when recording.
Re: New SkyQ box but no red light
Hi @SPhelps1952
Try a Reset Settings in the Q box hidden menu.  See if this wakes it up!
Avatar for SPhelps1952
Thanks, tried that but still no red light. Not too concerned, just a minor niggle.
This message was authored by: Nicoledo
Also just received a new sky q box. Red recording light doesn't work. Did the reset, but that does not work
This message was authored by: SteveHamer
Our first Sky Q box lasted, well, I don't know how many years, and was perfect but eventually the Hard Drive packed in and we had a replacement.
That replacement didn't remember recordings that were set when it powered down and itself was replaced (at my expense to call out the engoneer!!?)
That one is the current box and that works fine apart from it never shows the red light when recording which is surprisingly annoying. Resets of all kinds, power cycles and updates have not fixed the red light not coming on and I'm reluctant to ask for yet another box.
Are there no other solutions?
@SteveHamer probably not
I would guess if the red light is not coming on at all then the bulb has blown. If the red light shows when the box is in eco mode then it would appear to be the signal that is sent when the box is recording is probably not being sent in both circumstances I woud expect you would need a replacement box
This message was authored by: Otoshi
I have exactly the same issue. Had the same box for years and eventually the hard drive packed in. Engineer replaced the box the. A few weeks later the new box developed a fault and had to be replaced,  this time the recording light on the replacement box does not work and the box was dusty so it's pretty clear that 'new' replacement boxes are reconditioned in many/most cases.
@Otoshi I would guess that the majority of boxes now a days are reconditioned seeing as all Q boxes are loaned to you.
