Discussion topic: New Sky Q remote does not control sound
This message was authored by: Chatsy
I have bought a new Sky Q remote control, went through the set up stages and although it controls everything else it does not control the sound, I have an LG TV model 47LA790W-ZA.
Please help
Re: New Sky Q remote does not control sound
Have you paired it with the Q box AND TV?
Avatar for Chatsy
Hi Chodley,
Thank you for your answer.
 I see that you can only have one remote paired with the box so is that the problem?
I wanted to have two paired..
@Chatsy wrote:
Hi Chodley,
hi @Chatsy
It can be done but rather convoluted.
Only one can be paired in bluetooth mode (& thus Voice control) - the other(s) has to be IR only
You first pair the one(s) you want to use in infrared only mode (pressing & holding 7 & 9 if needed to reset) by pressing & holding 1 & 3 together & following the on screen instructions
Once paired to the box & TV you reset it to use Infrared by pressing & holding 4 & 6 together
Then you re-pair the one you want to use in bluetooth mode & for voice contro, as above but this time don't press the 4 & 6 after
