Discussion topic: New Sky Q remote does not control sound
This message was authored by: Chatsy
I have bought a new Sky Q remote control, went through the set up stages and although it controls everything else it does not control the sound, I have an LG TV model 47LA790W-ZA.
Please help
Re: New Sky Q remote does not control sound
Have you paired it with the Q box AND TV?
Avatar for Chatsy
Hi Chodley,
Thank you for your answer.
 I see that you can only have one remote paired with the box so is that the problem?
I wanted to have two paired..
@Chatsy wrote:
Hi Chodley,
hi @Chatsy
It can be done but rather convoluted.
Only one can be paired in bluetooth mode (& thus Voice control) - the other(s) has to be IR only
You first pair the one(s) you want to use in infrared only mode (pressing & holding 7 & 9 if needed to reset) by pressing & holding 1 & 3 together & following the on screen instructions
Once paired to the box & TV you reset it to use Infrared by pressing & holding 4 & 6 together
Then you re-pair the one you want to use in bluetooth mode & for voice contro, as above but this time don't press the 4 & 6 after
Avatar for Chatsy
Hi Nigea99,
thanks for getting in touch.
I've tried all that but no joy. I'm starting to think that the new remote is faulty.
Does it still control the sky box in IR mode?
Does the first / primary remote control the TV using IR ok?
