Discussion topic: New Build and am not allowed my satellite dish. Now what as I want to record television
Message posted on 29 Jun 2024 04:28 PM
I am in desperate need to get clarification on how can I get Sky Q so that the dish is not visible from the outside. I am in a new build.
Message posted on 29 Jun 2024 04:38 PM
Re: New Build and am not allowed my satellite dish. Now what as I want to record television
If you're not allowed a dish then you can't have Sky Q.
Message posted on 29 Jun 2024 04:41 PM
@Hettema the only way I can think of is to mount the dish onto a pole in the back garden assuming you have a garden pointing in the same direction as the front of house
Message posted on 29 Jun 2024 04:43 PM
My garden is behind the house. Apparently, I would need to have it on top of my roof with an arm extender.Not sure how great this would be.
Message posted on 29 Jun 2024 04:52 PM
hi @Hettema
Have you spoken to the builders/ housing management to see if they possibly have set up a communal feed to the property.
I know most probably do not but I think some that do have such retrictions have provided houses with a communal feed alongside other fibre services
Message posted on 29 Jun 2024 04:55 PM
I presume that they do not as they state that Sky must put it in the loft like other houses. Somehow, I do not think that is possible. Am i incorrect?
Message posted on 29 Jun 2024 05:23 PM
@Hettema wrote:I presume that they do not as they state that Sky must put it in the loft like other houses. Somehow, I do not think that is possible. Am i incorrect?
Terrestrial aerials work in lofts, satellite dishes do not.
Q needs a dish or a feed from as such (there are various communal methods but it would seem not to apply here).
Message posted on 29 Jun 2024 05:39 PM
@Hettema If your garden is large enough you might be able to have a local satellite specialist engineer install a satellite dish on a pole looking over your roofline to the Astra 28.2 East satellite cluster.
Godfrey.
Message posted on 29 Jun 2024 05:56 PM
You are not incorrect.
the very weak signals reaching the earth from approx 2200 miles above the equator struggle to get through Tree foliage so any Roof material is a none starter.
It is amazing what advice can be given - but then again the people who come up with such regulations seem more bothered about Architectual aesthetics rather than customers needs
