Discussion topic: Network
Message posted on 15 Aug 2023 06:28 PM
Network
I have no network connection. All green lights on router but no app's available/sky cinema etc on our two sky Q boxes
Message posted on 15 Aug 2023 06:44 PM
Re: Network
Hi @MrAndyg
First connect your Main Q box by Carrying out a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
When (or if) you get the main Q box connected reboot the main Q box.
once the Mai Q box is back up and fully running Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
