This discussion topic has been answered Discussion topic: Network set up
Message posted on 09 Apr 2024 05:35 PM
I recently set up a new FTTP connection to our apt and have tried to manually resetting the connection as I found that I could no longer watch my recordings on the ipad or use the remote control facility on Skygo. When I swapped I was obviously properly connected to my old Pine Media connection and it has now reconnected to a neighbour's network. When I type in the password it won't accept it.
i have read a solution on another thread but as I am disabled that would be difficult to follow. Is there a simple solution?!
Message posted on 12 Apr 2024 10:58 AM - last edited: 12 Apr 2024 10:59 AM
@MH1901 wrote:
@oldfella more trouble - Put Sky mini box on - checked on the right network but won't connect - error message MR104. This means rebooting mainbox (and hope it reconnects onto the right network) then ?reboot mini box - is that right?. (Reboot switch off at wall and wait 30 seconds?) thank you.!
Hi @MH1901
Reboot the mini as above.
Message posted on 09 Apr 2024 05:54 PM - last edited: 09 Apr 2024 06:08 PM
Re: Network set up
Hi @MH1901,
Are you on about your Sky Q box is connected to the Neighbours WiFi or your iPad?
In any case reset the network on the Q box by following the instructions below, please note, if you are with a 3rd party Internet Service Provider it will show a random "SKYXXXXXX" SSID (WiFi Network Name) on the network settings of your Q box as the Sky Q box creates it's own little network.
To initiate a Network Reset, navigate to Q box Home > Settings > Setup > Network. Once there, highlight "Status" and then choose "Reset" from the options on the right-hand side. Follow the provided instructions to establish a WiFi connection with your router.
If you're using Sky broadband, you'll be prompted to press the WPS button on the Sky router. Remember to press the WPS button on the Sky router itself and not the reset button on the Q box, as the Network reset will automatically trigger the WPS process on the main Q box.
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Message posted on 09 Apr 2024 06:12 PM
Re: Network set up
Thank you for your reply, - I had already gone onto settings and tried manually resetting the system - the SkyQ found my new hub - I clicked on that and entered the password as instructed which it wouldn't accept. I think that that was what you suggested?
Message posted on 09 Apr 2024 06:14 PM
Re: Network set up
Is the new router close to the Sky Q box?
If it is I would recommend using an ethernet cable to hardwire your Q box to the NEW Router
Message posted on 09 Apr 2024 06:29 PM
Re: Network set up
Thank you - if that is the only way then I will need to buy another ethernet cable as I stopped using them years ago and then ask someone to come and try your suggestion unless someone has any other solution?!
Are you sure that will work and will they have to stay connected using the cable?
Message posted on 09 Apr 2024 06:33 PM
Re: Network set up
It should connect via WiFi, I would double check the password you are entering is correct as some charaters looks like numbers but they are letters and vice versa for example a lowercase L can look like a capital I.
The WiFi password is also case sensitive
Message posted on 10 Apr 2024 01:36 AM
Re: Network set up
Password definitely correct.
Message posted on 10 Apr 2024 09:39 AM
Re: Network set up
Message posted on 11 Apr 2024 12:25 AM
Re: Network set up
@oldfella Thank you for responding - I am with Pine Media and have been with them for approximately 7 years.
Message posted on 11 Apr 2024 09:53 AM
Re: Network set up
Hi @MH1901
If you haven't already try the following procedure in the order given.
When the router is completely back and running
reboot the main Q box.
And then try a Network Reset found in Q box Home - Settings - Setup - Network.
As you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 11 Apr 2024 01:36 PM
Re: Network set up
@oldfella Thank you so much. I actually only had to do 1/2 of what you suggested. I disconnected the router for 30+ secs and thought I would try out of interest whether it worked. at that stage and reset the network connection including password and it's connected.. A very simple solution, I should have just thought of that before, but it may help someone else - thanks again @oldfella much appreciated.
Message posted on 12 Apr 2024 12:35 AM
Re: Network set up
Hi @MH1901
Message posted on 12 Apr 2024 12:36 PM
Re: Network set up
@oldfella @Thank you so much. Simple solutions for both issues. Checked connected to the correct network. We have peace in the household!
Message posted on 12 Apr 2024 12:39 PM
Re: Network set up
