Discussion topic: Disney plus not working and password not recognised for other apps
This message was authored by: Sarah195
I am trying to sign into paramount plus and it won't recognise my password. I also can't log in to sky go on my sons phone as it won't recognise password. Disney plus all of a sudden isn't working either. I have reset my password multiple times and nothing
Re: Disney plus not working and password not recognised for other apps
Hi @Sarah195
Depends what you set up for each App.
They all have to be set up with login details of your choosing.  Whether or not you chose different details only you know what you used for each App
Avatar for Sarah195
Paramount is asking for my sky Id and password as is sky go. I logged into Disney with my Disney details and it was working fine until today
Hi @Sarah195
Paramount plus does no ask for Sky ID and Password.
The Sky Activation procedure ask for this to take you to the Paramount~plus Website where you set up Email and Password of your Choosing.
https://www.sky.com/help/articles/using-paramount-plus
ie
You will be taken to Paramount+ to create your account. Enter your email address and choose a password, these do not need to be the same as your Sky iD.
Please double check you've entered your email address correctly before you create your account. If you have made a mistake, you'll need to contact Paramount+ to get it fixed.
Avatar for Sarah195
Right thank you. Any idea about the sky go or disney?
Hi @Sarah195
Sky Go does use your Sky ID and password.  Bear in mind that if you are trying to connect to your Q box using Sky Go you need the Monthly Sky Q Multiscreen subscription..
With Disney +. If you subscribe through Sky and follow the Activation procedure then you do use your Sky ID to create a Disney account similar to Paramount plus.  However whether or not you have to setup more login details on the Disney website I'm not sure
https://www.sky.com/help/articles/sky-marketplace-subscribe-to-disney-plus
Avatar for Sarah195
Spoiler
Thanks for the help
