Discussion topic: Network error
Message posted on 04 Oct 2025 09:13 PM
Re: Network error
I Remember you saying that it was just the sky agent asked if I could disconnect any 3rd party boosters before restarting
as long as it works fine where it's at may just leave it there
as long as wife gets multiroom box upstairs then she's happy with all the footy
cheers
Message posted on 04 Oct 2025 10:29 PM
Re: Network error
You can connect a Q to an eero via ethernet though
Message posted on 04 Oct 2025 10:55 PM
Re: Network error
Too far away unfortunately as different ends of each room.
thinking about the mini Eero as boosters but price is of putting
cheers though
Message posted on 04 Oct 2025 11:00 PM
Re: Network error
Sanity is worth a fair chunk of change 🤣
Message posted on 05 Oct 2025 08:09 AM
Re: Network error
@gypsyroadhog wrote:
thinking it may be cabinet I opened the doors and pulled Q out slightly which seemed to work.
Sounds like it is your tv cabinet restricting the signal.
See you mention glass doors. Glass can be a cause of interference or restricting the signal as glass doors or even having something like a Sky TV device sitting on a glass shelf.
Would suggest;
Either buy a new tv cabinet that is of an open design front and back.
Or remove the back of your current TV cabinet and also remove the doors at the front.
Message posted on 05 Oct 2025 08:40 AM
Re: Network error
I suggested that too and wife had a fit 😂 seems fine at the moment but time will tell
thanks for reply
Message posted on 19 Nov 2025 12:10 PM
Re: Network error
Hi all
update on this, they changed the box to a "better" box but after awhile it still persisted so they returned and they added a "mesh" behind the tv and wired it in.
1hr in and it's still fine😉 so we'll see how things fair, thanks all for comments and advice
