Discussion topic: No satellite signal
This message was authored by: Kate240
No satellite signal
We have no satellite signal
Re: No satellite signal
@Kate240
With a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
🔹 wind and rain can affect the satellite signal,
🔹a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored,
🔹following adverse weather wait times for an engineer will probably be significantly longer.
