Discussion topic: Network connection
Message posted on 20 Sep 2025 03:29 PM
Network connection
Message posted on 20 Sep 2025 03:54 PM
Re: Network connection
@MillyandMandy wrote:
Since last night I have lost my main sky box wifi connection. Even after resetting it. The connection had been lost again. Any advice?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
