Discussion topic: Network connection
Message posted on 01 Jan 2025 09:31 AM
							Network connection
We had a new router fitted about three months ago since then it continues to lose connection with the sky Q box . We have had an engineer attend but the fault continues.
Message posted on 01 Jan 2025 11:41 AM
							Re: Network connection
Hi @Clayt1955
Have your tried completly resetting your connection?
If you have the new Sky Max router on Sky broadband try using 3rd party router setup and not WPS.
