Discussion topic: No signal
This message was authored by: Barnaby2
No signal
No sky working no signal
Re: No signal
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
BTW Please note it can be a few weeks before engineer appointments
Re: No signal
@Barnaby2
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you are seeing a message of “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s almost certainly a dish alignment issue so follow the advice provided by @nigea99
