Discussion topic: Network connection
Message posted on 13 Sep 2024 06:02 PM
Network connection
Ive checked everything but it says theres an x next to network connection cant see any of my apps netflix, sky cinema, etc turned every thing off still not there but says theres nothing wrong but no apps
Message posted on 13 Sep 2024 06:15 PM - last edited: 13 Sep 2024 06:15 PM
Re: Network connection
Hi @Bellaboo12
If you still have no Apps
Have you tried refreshing the Apps in the Hidden menu.
Select Apps
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
