Discussion topic: Network connection
This message was authored by: Shootingstar198
Network connection
Whilst watching tv the last 25 hours it stops and comes up with network connection failed. I have reset this multiple times and this still hasnt resolved. Please can anyone advise. Its very frustrating. Broadband has also been playing up
Re: Network connection
Do you think the broadband playing up might be the root cause of the sky Q box losing its connection?
Shouldn't affect live TV though. Or are you on Stream and not Q?
This message was authored by: MUSICMAN1
My sky Q box is doing exactly the same, reconnect to my broadband which is ( virgin media) then it drops out/ disconnects, broadband is working fine, all other devices connected to the broadband are working fine, this has been playing up for the last few months, are we waiting for a software upgrade to iron the bugs out or could there be a problem with my sky Q box, anyone else having these connectivity problems or is it just mine
Anyone? Try searching in here, it's one of the most common problems.
Try powerline adapters instead of wifi.
