Discussion topic: Network connection issues, cannot get any sky programmes like sport for example
Message posted on 21 Jul 2024 09:07 PM
I have an issue. I have a satellite signal but no network connection. I clicked on network connection and then network setup. I click connect to sky broadband wi-fi as I have a sky broadband router. It searches. Then a message comes up' to complete the connection press and hold the WPD button on the broadband router but there isn't one.
I have tried to virtual agent and that was useless.
I have called Sky, got another robot who sent a text then put the phone down on me!!.
Message posted on 21 Jul 2024 09:12 PM - last edited: 21 Jul 2024 09:13 PM
Re: Network connection issues, cannot get any sky programmes like sport for example
Hi @Esined1
All routers have a WPS button
On Sky routers see below
To reset your connection
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Message posted on 21 Jul 2024 09:30 PM
Tried with pressing the button on the side of the router and it has come back with a message unsuccessful connection, please try again or you may need a sky Q booster.
Message posted on 21 Jul 2024 09:33 PM
Message posted on 21 Jul 2024 09:34 PM
It still is flashing on the Sky Q box
Message posted on 21 Jul 2024 09:36 PM
Not flashing now has disappeared
Message posted on 21 Jul 2024 09:39 PM
Hi @Esined1
When you carry out the Network reset on the main Q box it's WPS light will only flash for two minutes.
If you do not press the Router WPS button within this time it will not connect.
The WPS light on the main Q box should not carry on flashing.
Message posted on 21 Jul 2024 09:44 PM
Let me try the connection again and see if it works this time
Message posted on 21 Jul 2024 09:50 PM
Tried again and still did not work.
