Discussion topic: Mini box not working
Message posted on 21 Jul 2024 08:58 PM
Hi my sky mini box isn't working
and I have reset it and tried to reconnect to the sky main box
Message posted on 21 Jul 2024 09:06 PM
Re: Mini box not working
Hi @Md231
Reboot the mini as above.
