Discussion topic: Network Connection
Message posted on 21 Sep 2023 02:55 PM
Network Connection
My Sky TV Settings is saying no Network connection I have switched the router off and on to try to reset this but no effect
Message posted on 21 Sep 2023 06:37 PM
Re: Network Connection
Hi @ErniePurvis
Assume this is your main Q box.
Have your carried out a Network reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
