Discussion topic: Not connected
This message was authored by: R+WALLER
Not connected
Not connected
Re: Not connected
@R+WALLER  I'm afraid you will need to provide more info
Not connected to what?
Re: Not connected
@R+WALLER wrote:
Not connected
What is not connected @R+WALLER ???
If it is your main Q box to your Router then
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
