Discussion topic: Netflix
This message was authored by: Kaysback
Netflix
My sky won't let me on Netflix and I spy with my package
Avatar for Kaysback
Re: Netflix
I pay for Netflix with my sky package but it won't let me on
This message was authored by: twilight+princess
Re: Netflix
Is there any error message?
Are you signing into Netflix with your Sky details or trying to set up a new account?
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Avatar for Kaysback
Re: Netflix
It's coming up with someone else details not mine
Re: Netflix
Is there any error message option to sign out allowing you to sign in?
It sounds like you've been hacked.
Virginia.
Avatar for Kaysback
Re: Netflix
Yes but when you do that it just comes back with that same account
Re: Netflix
If you choose sign out then it should ask for sign in details.
Are you doing this via the Sky box/TV, Netflix app or online? If via Sky then try online to see if the details still work.
If not then you'll need to contact Netflix directly.
Virginia.
Re: Netflix
@Kaysback is the account it's coming up with in Spanish if so That sounds as though your Netflix account has been hacked. In these situations you will need to contact Netflix who will be able to reset your account.
You can contact Netflix on the link below
https://help.netflix.com/en/contactus
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
