Discussion topic: Netflix
This message was authored by: BillandBen1
Netflix
I'm trying to upload Netflix to a second tv.  The main tv has Netflix and runs no prob. The second tv I'm trying to load it on to doesn't have sky but an Amazon fire stuck.
Re: Netflix
Hi @BillandBen1
See Netflix help.
https://help.netflix.com/en/node/23934#
This message was authored by: Padam_Padam
Re: Netflix
You would need to download the Netflix app to your Amazon Firestick from the Amazon app store on the Firestick. Once you have done that you need to login to the Netflix app with the same username and password you used when you set up the Netflix account.
