Discussion topic: Netflix
This message was authored by: Anne889
Netflix
I am unable to use my phone to watch Netflix it's asking me to sign up again already with sky Netflix what to do ? My Netflix on the tv is fine
Re: Netflix
hi @Anne889
You need to make sure you are using the same email & password as used for Netflix on SKY Q
To check the email address you used :
On the SKy Q App
open Netflix
Press Left Arrow to activate the Left hand Menu
Scoll down to bottom line & then Tab accross to ? Get Help & Select
Against the Member entry it lists the Account Email for the account
