Discussion topic: Netflix
This message was authored by: K_10
Netflix
I have a netflix account
It gives an error code on my samsung tv
tvq-pb-101(5.6.1)
i then linked my account to sky q
still getting the same error
Spoke to netflix and tried resetting but still the same
Re: Netflix
tvq-pb-101(5.6.1)
Hi @K_10
Check the following link.
https://help.netflix.com/en/node/51955
This message was authored by: scouselfc
Re: Netflix
i have the same problem aswell even itvx and disney wont work either ....tried all tests says connected
think sky is having problems ...they should check
Re: Netflix
update sky q goto settings and update software
will take 10mins then press power button to stand by
takes a few mins ..
press power button
wait till loads up
you should be back on line i did it and now all works itv x netflix and disney !!
