Discussion topic: How to stop main box for idling
This message was authored by HelenDun This message was authored by: HelenDun
Hi
Currently doing renovations and I don't have easy access to my main Skyq box. The secondary mini box keeps losing signal as the main box keeps going into an idle state. How do I stop this happening?
This message was authored by xenon81 This message was authored by: xenon81
Re: How to stop main box for idling
Could it be a connection problem between the main box and mini, has the main box been moved from its usual place while the renovations take place?
Sky Q boxes only go into an eco mode between 2:45-5:45am.
HelenDun
Still in its normal spot . Getting MR 104 code lots
Covered in dust sheets or surrounded by paint tins?
If it wasn't doing this before, look for local physical changes, or something like 'noisy' electrical device use.
HelenDun
I'm not sure what you mean by "noisy" electrical devices.  I'm now getting a. MR 106 error
The errors indicate that there is a signal issue between the main box and mini, if the box is still in the same place perhaps a booster (if any) has been unplugged or something is causing interference. If everything was working before the renovations then hopefully it will work again when they're complete.
This message was authored by Chodley This message was authored by: Chodley
Noisy as in they produce lots of EM interference.  E.g. drill motors.
