Discussion topic: Netflix
This message was authored by: nobby24
Netflix
I want to log out of my Netflix account on my Sky Q Box permanently but the next time I run the app it logs straight back in, I have even changed my email and password and it still logs in, I have also done a full reset on the q box.
Re: Netflix
Hi @nobby24
Have you actually logged out in the Netflix menu?
ie
In the left hand Menu in Netflix App on your Q box go the left hand menu and scroll down to the bottom.
Then scroll right and select
Get help.
On the next screen there is an option to Log out .
If you still have an issue you can go to the Netflix website and sign into your Account.
There is then the option to log off of all devices
Avatar for nobby24
Re: Netflix
yes I have done both, on Sky Q it says I have logged out if I click login in goes to the login menu password etc. If I don't enter anything and just run the Netflix App it just logs straight back in. Its driving me made. I have changed my email and password on the Netflix website and never entered the new details on the sky box and it still logs in!
